Hi friends,
I am using AT91SAM7SE512 controller with keil.
I am having the USB CDC code for AT91SAM7S64 controller in IAR tool.
I want to convert the code from IAR to Keil .
How can i do this? for this did i change or include any files?
i already asked in the forum no one is giving reply?
could you please help me...
with regards, Murthy.R
What about this, then: http://www.keil.com/forum/docs/thread11465.asp
But your previous thread said that you have converted it: http://www.keil.com/forum/docs/thread11502.asp
"for this did i change or include any files?"
I don't know - did you?
Some key things you need to consider when porting from one compiler to another are:
* Implementation-Defined Behaviour - such as data representations, calling conventions, etc;
* Language extensions;
* Dependence on specific non-standard libraries.
Did you carefully check all of them?
What debugging have you done on your converted code?
