Long Integer Multiple Error. Sample Program: Target Setting: MCU is C8051F120F, Use On-chip Arithmetic Accelerator.
Source:
#include <C8051F120.H> #include <stdio.h> unsigned long Freq; void DetectFreq() { unsigned long N; unsigned char M; SFRPAGE = CONFIG_PAGE; M= PLL0MUL; switch (CLKSEL&0x03) { case 00: //Internal XTAL case 03: Freq=25690112;//24.5L*1024L*1024L switch(OSCICN&0x03){ case 0x00: Freq/=8; break; case 0x01: Freq/=4; break; case 0x02: Freq/=2; break; } break; case 01: // External XTAL Freq=25L*1024L*1024L; switch (OSCXCN&0x70) { case 0x03: case 0x05: case 0x07: Freq=Freq/2; break; } break; case 02: //PLL if (PLL0CN&0x04) { // External XTAL Freq=26214400L; //25L*1024L*1024L N=Freq; Freq*=PLL0MUL; Freq/=PLL0DIV; switch (OSCXCN&0x70) { case 0x03: case 0x05: case 0x07: Freq=Freq/2; break; } } else{ //Freq=25690112L; Freq=24500000L;//25690112L; N=Freq; Freq*=PLL0MUL; //FreqMul(PLL0MUL); Freq/=PLL0DIV; switch(OSCICN&0x03){ case 0x00: Freq/=8; break; case 0x01: Freq/=4; break; case 0x02: Freq/=2; break; } } break; } SFRPAGE = LEGACY_PAGE; printf("%lu * %u = ", N, M); printf("%lu\n", Freq); Freq=25690112L; printf("%lu * %u = ", Freq, 4); Freq*=4; printf("%lu\n", Freq); } void InitSerial() { SFRPAGE =LEGACY_PAGE; SCON0 = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */ TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */ TH1 = 221; /* TH1: reload value for 1200 baud @ 16MHz */ TR1 = 1; /* TR1: timer 1 run */ TI0 = 1; /* TI: set TI to send first char of UART */ } // Peripheral specific initialization functions, // Called from the Init_Device() function void Reset_Sources_Init() { WDTCN = 0xDE; WDTCN = 0xAD; } void EMI_Init() { SFRPAGE = EMI0_PAGE; EMI0CF = 0x1F; //EMI0TC = 0x4F; EMI0TC = 0xCF; } void Port_IO_Init() { SFRPAGE = CONFIG_PAGE; P4MDOUT = 0xFF; P5MDOUT = 0xFF; P6MDOUT = 0xFF; P7MDOUT = 0xFF; XBR0 = 0x07; XBR1 = 0x94; XBR2 = 0x40; } void Oscillator_Init() { data int i = 0; SFRPAGE = CONFIG_PAGE; CCH0CN &= ~0x20; SFRPAGE = LEGACY_PAGE; FLSCL = 0xB0; SFRPAGE = CONFIG_PAGE; CCH0CN |= 0x20; PLL0CN |= 0x01; PLL0DIV = 0x01; PLL0FLT = 0x01; PLL0MUL = 0x04; for (i = 0; i < 15; i++); // Wait 5us for initialization PLL0CN |= 0x02; //while ((PLL0CN & 0x10) == 0); CLKSEL = 0x02; OSCICN = 0x83; } // Initialization function for device, // Call Init_Device() from your main program void Init_Device(void) { Reset_Sources_Init(); EMI_Init(); Port_IO_Init(); Oscillator_Init(); } void main() { Init_Device(); InitSerial(); printf ("Hello World\n"); /* Print "Hello World" */ DetectFreq(); printf("%lu", Freq); while(1); }
======================end of source========================= Run Result:
Hello World 24500000 * 1024 = 4294926936 25690112 * 1024 = 1568 1568
conclusion:
1.There are mistake of Long Integer Mutiple where open the on-chip arithmetic accelerator. 2.printf also make a mistake of Printing a one-byte-integer.
you have maths overflow i think
results are undefineded for maths overflow of integer dont they
i dont be think this is bug
also i thinking your code do not say
25690112 * 1024 =
it say
25690112 * 4 =
also
why you conclusion printf also make a mistake of Printing a one-byte-integer
who evodence for this?????
"2.printf also make a mistake of Printing a one-byte-integer."
More likely, you made the mistake - you didn't read the Manual carefully, and didn't follow the specific instructions about passing single-byte integers to printf...
http://www.keil.com/support/man/docs/c51/c51_printf.htm
Think you. I modified my source :
printf("%lu * %bu = ", N, M); printf("%lu\n", Freq); Freq=25690112L; printf("%lu * %bu = ", Freq, 4); Freq*=4; printf("%lu\n", Freq);
It work correctly. but the Long Integer Multiple fault also.
Run Result: 24500000 * 4 = 4294926936 25690112 * 4 = 1568
