dear all, i defind a struct in a head file and other file will be use this struct , i use keyword extern but always has warning or error message , please tell me really method. thanks a lot.
main.c ---------------- typedef union{ unsigned char Byte; struct{ unsigned _40:1; //Cmd 0 unsigned _41:1; //Acmd 41 unsigned _50:1; //Cmd 16 unsigned _49:1; //Cmd 9 unsigned b4:1; unsigned b5:1; unsigned b6:1; unsigned b7:1; }Audio; struct{ unsigned _51:1; //Cmd 17 read_single_block unsigned _58:1; //Cmd 24 write_single_block unsigned xx1:1; //Cmd 16 unsigned xx2:1; //Cmd 9 unsigned xb4:1; unsigned xb5:1; unsigned xb6:1; unsigned xb7:1; }Bits; }_Data; _Data init_flag; other.c ---------------------------------- extern struct _Data init_flag;
The code snippets you posted directly contradict that statement. There's no header file in sight.
Defining the struct is what you should do, but it's not what you're doing.
dear , sorry sir , i not define in head file , define in main.c .
but i define in head file now , still have error message.
Have you placed the declarations (including the extern declaration) in the header file?
Have you included the header file from all source files that need to access the variable or data type?
Have you instantiated the variable in one - and exactly one - source file?
