Hi Timo Ollikainen,
Have you ported the example codes to the Keil compiler.
If you have done so, could you send them to me:
furkansahin@gmail.com
I am starting a new project with the CC2430 and probably need quite a lot of your help.
Which example did you mentioned? Which environment had it been developped? Which language,and What is CC2430?
Before you getquite a lot of help,you are supposed to supply some information.
I tried to write the message in reply to the following message but it looks I could not:
http://www.keil.com/forum/docs/thread7110.asp
Hi!
I would like to use KEIL's C51 tools for Chipcons CC2430 instead of IAR's buggy IDE... What is the best way to port the Chipcons example files (from their website) writen for IAR's EW? Has someone allready done this and is there a downloadable conversion available? Chipcon's IAR deal seems to limit their support in this issue...
"I tried to write the message in reply to the following message but it looks I could not:"
Yes, that is what "Read-Only" means!
Anyhow, I think that thread has pretty much covered everything. There's nothing else I'd add here that I haven't already said there.
What, specifically, did you want to know that wasn't convered there?
