I use RTL for LPC214x, and I want to test the time used for my own code, how can I do that with RTL? Does RTL provide some function like GetTimeCount() in VC++?
No, it really does not.
The "Easiest" way to do this would be add a u32 counter to the RTX_Config.c file in the os_chk_robin() function. (before the #if (OS_ROBIN == 1). increment this counter every time the os_chk_robin() function is called (which should be called on every OS Timer Tick, the rate you have set up in the RTX_Config.c File.
u32 osTickCount; void os_chk_robin(void) { osTickCount++; #if (OS_ROBIN == 1) ... #endif } u32 getTickCount() { u32 value; tsk_lock(); value = osTickCount; tsk_unlock(); return value; }
