ARM LPC2129..how to assign port pin as input pin
Dear sir,
herewith i attach my program for your reference, if any one knows the solutions plz kindly provides some help for me.
My programs is to assign LPC2129 Port P1's any of the pin is input, when the pin is high, it gives beep sound, otherwise sends character 'A' to serial port.
my doubt is how to assign port1 as input pin,
Program
#include <LPC21XX.H>
unsigned int delay;
void init_serial (void);
void delay1(void);
void alert(void);
//Delay Routine
void delay1(void)
for(delay = 0;delay<0xA0000;delay++)//simple delay loop
//Alert Function
void alert(void)
IOSET1 = 0x00010000;
delay1();
IOCLR1 = 0x00010000;
delay1();
//Initialize serial
PINSEL0 = 0x00050000; /* Enable RXD1 TxD1 */
U1LCR = 0x00000083; /*8 bits, 1 Stop bit */
U1DLL = 0x000000C2; /*9600 Baud Rate @12MHz VPB Clock */
U1LCR = 0x00000003; /* DLAB=0*/
//Main program starts
int main (void)
PINSEL0 = 0;
PINSEL1 = 0;
PINSEL2 &= 0x0000000C;
VPBDIV = 0x02; //Divide Pclk by two
IODIR1 = 0x00000000; // set all pin to input
init_serial();
while (1)
if(IOSET1==0X02000000) //check P1.25 is high
alert(); //call alert function
else
U1THR = 'A'; //send 'A' char to serial port
