hi friends, this is my very first post in this forum. I'm trying to interface a 32Kbits EEprom 24c32 with AT89c52, but i'm not able to achieve the goal. I found this code for 24c256 EEPROM on net which i'm using, but i think there should'nt be a difference for 24c32.
//--------------------------------------- // 24LC256 I2C EEPROM driver // http://www.GetMicro.com //--------------------------------------- #include<reg8252.h> #include<intrins.h> # #define ACK 1 #define NO_ACK 0 unsigned char i; sbit SDA = P2^1; // connect to SDA pin (Data) sbit SCL = P2^0; // connect to SCL pin (Clock) //------------------------------- // start I2C //------------------------------- void Start(void) { SDA = 1; SCL = 1; _nop_();_nop_(); SDA = 0; _nop_();_nop_(); SCL = 0; _nop_();_nop_(); } //------------------------------- // stop I2C //------------------------------- void Stop(void) { SDA = 0; _nop_();_nop_(); SCL = 1; _nop_();_nop_(); SDA = 1; } //------------------------------- // Write I2C //------------------------------- void WriteI2C(unsigned char Data) { for (i=0;i<8;i++) { SDA = (Data & 0x80) ? 1:0; SCL=1;SCL=0; Data<<=1; } SCL = 1; _nop_();_nop_(); SCL = 0; } //------------------------------- // Read I2C //------------------------------- unsigned char ReadI2C(bit ACK_Bit) { unsigned char Data=0; SDA = 1; for (i=0;i<8;i++) { SCL = 1; Data<<= 1; Data = (Data | SDA); SCL = 0; _nop_(); } if (ACK_Bit == 1) SDA = 0; // Send ACK else SDA = 1; // Send NO ACK _nop_();_nop_(); SCL = 1; _nop_();_nop_(); SCL = 0; return Data; } //------------------------------- // Read 1 byte form I2C //------------------------------- unsigned char ReadBYTE(unsigned int Addr) { unsigned char Data; Start(); WriteI2C(0xA0); WriteI2C((unsigned char)(Addr>>8)&0xFF); WriteI2C((unsigned char)Addr&0xFF); Start(); WriteI2C(0xA1); Data = ReadI2C(NO_ACK); Stop(); return(Data); } //------------------------------- // Write 1 byte to I2C //------------------------------- void WriteBYTE(unsigned int Addr,unsigned char Data) { Start(); WriteI2C(0xA0); WriteI2C((unsigned char)(Addr>>8)&0xFF); // send address high WriteI2C((unsigned char)Addr&0xFF); // send address low WriteI2C(Data); Stop(); }
Please help me out.
With best regards Neelam
I would like to help you, but I do not have the time to decipher your scribbles.
scribbles: NOTHING without comments can be called 'code'
At the very least I would add a few _nop_(); in your ReadI2C and WriteI2C routines between all changes to SDA and SCL lines because - unless you are using a very slow processor XTAL - you will probably be toggling the lines at >400kHz for 'High Speed' I2C and most definitly >100kHz for the 'standard' I2C.
So check your processors XTAL so you can work out how long it takes to execute a nop instruction then check the I2C timing requirements and add (more than) enough nops to bring the I2C bus timings into spec.
Mark.
