Hi. I used the following code, and appeared the error "error C110: non-constant case/dim expresion" at the "case" line, what does it mean? ...
void main(void){ char command[]={1,2,3,4,5,6,7,8}; char word; //........ while(1){ /* ......... some lines of code */ switch(word){ case command[0]: // do somthing break; //................... case command[7]: // do somthing break; } } }
Thank you.
It means that your code is not valid C.
In a switch statement, every case must be constant value - not a variable or a function call. All cases must also be unique.
A constant value may be a numeric value (15), a character constant ('A'), a hexadecimal constant (0x10) etc.
But I also tryed this, and the same error:
const char[]={1,2,3,4,5};
As PerSo Westermark said, "every case must be constant value - not a variable..."
