Counter and printf
Hi all
I need a counter to to count up something
So I use follow code to do this work
unsigned long pdata counter[4]={0,0,0,0};
in the counting place,
counter[0]++;
when run finsih , I print the result
printf(%ld\n",counter[0]};
Maybe I have run to 1000 times ,so counter[0] value
will be to 1000 , but the printf result maybe very
large, like as 92343421;
why ?? how can I make sure to count up correctly??
Thanks a lot
best regards
  • printf(%ld\n",counter[0]};
    That line contains two typos and wouldn't even compile - so it is clearly not the actual code that you are using!
    You must you copy-and-paste to post your code!
    Post the smallest complete example that illustrates the problem.
    Have tested this in the Simulator?
    What debugging have you done?
    Are you sure your PDATA is working & correctly configured?
