I am going to use ULINK programmer for flash burning. while doing so i need following details.
1.What is the part number of 10 pin JTAG connector? 2. So that i can select the approporiate male connector on the PCB?
Did you really read my post?
There are multiple connectors on the ULINK2 device!
Information about the available connectors can - as I already mentioned - be found on this site.
See www.keil.com/.../ulink2_hw_connectors.htm
YEs, I am using ULINK2 programmer. I need to know the JTAG connector cable part no. so that i can use similar kind of male connector on my PCB.
I guess you are talking about the ULINK2 and not the older ULINK programmer.
It has several connectors, depending on target. Have you read the documentation available on this site?
