hi to all
i am started working on ad7705 16 bit ADC and my first experience on SPI communication. the follwing code i wrote to communicate AD7705 to AT89s52
/******************************************************************************************************/ #include <REGX51.H> #include<define.h> #include<intrins.h> /*******************************************************************************************************/ volatile unsigned int TimeTick1ms; char DispBuf[DGTS_ON_DISP]; int SPI_OUTDATA_BUFFER; sbit SPI_DIN = P1^4; // SPI D_IN sbit SPI_DOUT = P1^5; // SPI D_OUT sbit SPI_DRDY = P1^6; // SPI D_RDY sbit SPI_CLK = P1^7; // SPI CLK /*****************function declaration***************************/ void SPI_Write(char COMMAND_DATA); void SPI_Read(); void TMR_1(void)interrupt 3 { TR1 = STOP; TL1 = COUNT_LO_1mS; TH1 = COUNT_HI_1mS; TR1 = RUN; TimeTick1ms++; } void main(void) { char i; P0 = 0x3f; P1 = 0xff; P2 = 0xf8; P3 = 0xff; IE = 0x8A; TMOD = 0x11; /* T1 in 16-bit timer mode and T0 in 16-bit timer mode*/ TH1 = 0x63; TL1 = 0xBF; TR1 = RUN; V2F = 0; /**********************************************/ while(1) { SPI_Write(0x20); // Active Channel Ain1(+)/Ain1(-),Next Opraton Write to CLK REG. for(i=0;i<=10;i++) {_nop_();} SPI_Write(0x0C); // Master Clk Enable, 4.9512 MHz Clk , O/P Update rate 50Hz (20 mSec). for(i=0;i<=10;i++) {_nop_();} SPI_Write(0x28); // Active Channel Ain1(+)/Ain1(-),Next Opraton Read to CLK REG. for(i=0;i<=10;i++) {_nop_();} SPI_Write(0x10); // Active Channel Ain1(+)/Ain(-),Next Opraton Write to SETUP REG. for(i=0;i<=10;i++) {_nop_();} SPI_Write(0x40); // Gain = 1, Bipolar Mode, Buffer Off, Clear FSYNC, Perform Self Calibration. for(i=0;i<=10;i++) {_nop_();} // Clearing FSYNC bit Starts sampling. while(SPI_DRDY); //wait for DRDY to go LOW SPI_Write(0x38); // Active Channel Ain1(+)/Ain(-),Next Opraton Read From DATA REG. for(i=0;i<=10;i++) {_nop_();} SPI_Read(); for(i=0;i<=10;i++) {_nop_();} val = SPI_OUTDATA_BUFFER; V2F = enable; disp(val,Lable_No); } } /***********************************************************************/ void SPI_Write(char COMMAND_DATA) { char i; bit SPI_IN_BIT; for(i=0;i<=8;i++) { SPI_IN_BIT = (COMMAND_DATA&0x80);// bit isolation 7 times SPI_CLK = 0;// clk is low SPI_DIN = SPI_IN_BIT;// data on data din sends COMMAND_DATA <<= 1; _nop_(); SPI_CLK = 1;// clk is high } SPI_CLK = 1; // the clk line is high } /**********************************************************************/ void SPI_Read() { char i; for (i=0;i<=16;i++) { SPI_CLK = 0; SPI_OUTDATA_BUFFER = (SPI_OUTDATA_BUFFER | SPI_DOUT); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); SPI_CLK = 1; if(i < 16) {SPI_OUTDATA_BUFFER <<= 1;} } SPI_CLK = 1; }
As DIN and SCLK waveform i saw on the CRO that are proper i dont no where i am makeing mistake.
list of problem are as follow 1. i am not comfirm that AD7705 getting the data or not 2. is my spi routine is proper 3. after AD7705 configuraton DRDY high and it remains on that state 4. i am using 4 MHz crystal but as per data sheet they said to use 4.9152MHz or 2MHz.
help me to solve this
