When I try to run the debugger I get a ULINK - arm error:
"This product requires ULINK2"
I have v3.53 and ULINK V2.10...
This is my first time around the block. Is the message saying that my USB debugger/programmer is not a ULINK2 device? Help!
What debugger did you connect? What does it say on the box?
My guess is that you have the older original ULINK. In the mean time there's a new version: ULINK2 (wich is in big letters on the box itself).
Also in uVision you should see ULINK2 if you click "settings" in the "debug" tab of "options for target". Firmware version I have is 1.20, I think this is one of the most recent for ULINK2.
So probably you need to buy the ULINK2, or change to older uVision software.
