Hi all, I am using MCB2300 board from keil. I have the application to transfer hex bytes using ethernet. wat stuff should i study to clear my concepts regarding TCP/IP and which one application layer program could i use for the same.
We have a product called RL-ARM that contains an powerpul TCP/IP stack. You may review this documentation under: http://www.keil.com/support/man/docs/rlarm/rlarm_tn_tcpip_prot.htm
There is also an example project for the MCB2300 board under: http://www.keil.com/download/docs/328.asp
