hi, i'm tryin out a client server application where when i compile the prog in gcc it gives a list of errors sayin "undefined reference to.." all external references in that module.... u've suggested one solution before which points out the prob wit using .C(instead of .c)... but in my pogram everything is small letters... so any idea y???
please translate from Urdu or whatever language it is the following:
tryin prog sayin u've prob wit y???
well if it's so difficult for u to comprehend!!!..."hi, i am trying out a client server application where when i compile the program in gcc, it gives a list of errors saying "undefined reference to.." all external references in that module.... one of the replies to this question asked previously suggested a solution which points out the problem wit using .C(instead of .c)... but in this case that doesn't seem to be the problem... so any idea what it is???
well if it's so difficult for u to comprehend well, if it is so difficult for you to type clearly.
You, one person, save maybe 2 seconds and hundereds of readers waste time trying to comprehend your gibberish.
you refer to gcc, and the MCU is 'none' what MCU?
