Dears,
I am new to the world of embedded systems and i have LPC2294 board. I want to know to use the JTAG (not ulink) to download the test code which provided with Kiel to the board
Thanks a lot
BISO
You will need something that will connect to the board's JTAG, and your PC.
Keil's product to do this is the uLink.
If you don't want to use Keil' product (the uLink), then you'll have to find a 3rd-party device, and seek support from that 3rd party!
As Andy points out, the primary IDE JTAG interface for Keil uVision is the uLink. However, the Keil IDE does support the Seggar Jlink and the Signum JTAG. Drivers are included in the latest release of the MDK package. There are many low cost JTAG adapters on the market but they are not directly supported by the Keil IDE. Using a cheaper JTAG and much work around will spend more money than the cost of one of the supported JTAG devices. I know that you have an eval board but NXP(through their distributors) has the LPC2148 eval board with uLink2 for less than $150 US. Bradford
"Using a cheaper JTAG and much work around will spend more money than the cost of one of the supported JTAG devices"
Particularly as you say you're a newbie - this is not the kind of stuff you want to be messing with before you can even start, is it?!
