Fill of flash memory during reprogram UVision 3
I've got some code that saves setup information to flash if the user wants. I save a code to a memory location to let the software know that whether setup information is available or not. If not, I use defaults.
Is there some way on the UVision IDE that will automatically fill a segment of memory with a byte code when I reprogram? Without this capability, the code believes that there are always saved settings and this would be the quick fix.
Thanks in advance,
Matt
