RTL function disables jtag
I am trying to use RTL for the tcp communication part on the lpc2368 project. The stack ran ok on the lpc2378, but on 2368 it appears that the function Init_Tcpnet() somehow disables a jtag. After this function is executed, jtag doesn't connect anymore, giving an error "can't stop arm device". The only way to restore connection is to erase a chip with Flashmagic.
If I insert a loop before Init_Tcpnet(), connection never fails.
Pins and functions for ethernet are exactly the same for 2378 and 2368, so the reason is not in pin configuration, but somwhere else.
Did anybody have a similar problem?
Gennady
