ARM7: Filling Internal RAM of the processor
I wish to access & modify the contents of the internal RAM of the ARM7. How do I do that. I know that in the assembly file, there is a define statement for the starting of the RAM. But how do I access the contents (in fact the whole memory) from C code?
Thanks in advance,
avani
  • Avani,
    The RAM sections are defined via Target Dialog inside uVision, please refer to your device user's manual to see what valid RAM addresses are.
    To access RAM in C you may use a pointer. Anything in ARM will be pretty much done via pointers ( load-store characteristic ), in ASM you probably used LDR and STR instructions nothing fancy to be used on that purpose.
    C language doesn't know where your memory start/stop. It's your job to manage the access considering address and memory boundary ( check Thumb and ARM mode ).
    Hope it helps.
    Alex
  • Avani,
    Hope it helps.
    Alex
