Is there stand alone programmer software that uses the ULink? I need to program STR710FZ2T6 without using the uVision.
Thanks Juanjo
Here is another link which I just tried. The problem is that uVision opens as a pop-up during the flashing.
http://www.keil.com/support/man/docs/uv3/uv3_fl_hexdownload.htm
I sent an e-mail to Keil with a response of "currently there is no way to avoid the pop-up of uVision during the programming process. However there will be a utility in the future that avoids that. (Q3/2007).
Reinhard"
