please tell me about the configuration file(ram.ini)which is used for debugging applications using keil .my kit contains lpc 2129 arm controller.the error occurred is cant open the file.
the file is just use to change the PC location (it contains standard debug commands that are described in the uVision user's guide).
Take a look to the example:
C:\Keil\ARM\RV30\Boards\Keil\MCB2100\Blinky
