Hello
I'm making a career end project, and i've got to make a succesfull communication between the philips p89c668 microcontroller (8kb xram, 64 kb rom) and an anybus compactcom module to get fieldbus communication between a master and the microcontroller.
With the anybus compactcom module was shipped a generic driver.
My intention is to fit the driver in the host program in order to achieve the communication, but i've got some problems to do this:
1.- the fieldbuses can manage 64 bit data like double longs, double floats... can the uvision manage them? wich typedefs can i use?
2.- if anybody had done a similar implementation, can i have a watch over this?
Thank a lot for your attention, and excuse for my poor english. I can be weird, but I think that it is readable and can be understood.
"I'm making a career end project"
Do you really mean "career"?! "
uVision is just a "framework" that ties together all the different tools - compiler, assembler, linker, editor, debugger, simulator, etc.
See: http://www.keil.com/product/devproc.asp?t=c51&h=1
So the question is not whether uVision supports these things, but whether the Compiler supports them.
To find the answer to that question, you need to read the compiler Manual. Specifically, the available data types are listed here: http://www.keil.com/support/man/docs/c51/c51_le_datatypes.htm http://www.keil.com/support/man/docs/c51/c51_ap_datastorage.htm
"2.- if anybody had done a similar implementation"
Check the anybus compactcom module manufacturer's website for support information - application notes, examples, reference designs, etc. Your distributor/supplier may also be able to provide support...
I'm studying automatic and electronic superior technical engineering. University studyies. Here, in spain, it's diferent the way that the engineering studies are handled.
I've read the data types cart, and there is no reference to 64 bit data. Is there another way to do this? (with an struct of two doubles, or something like this...)
About the second cuestion, I'm going to take another look over the vendors website.
"I've read the data types cart, and there is no reference to 64 bit data"
Correct - that's because there isn't one.
The 8051 is just an 8-bit processor, so 32 bits is quite a lot for it!
"an struct of two doubles, or something like this"
Yes, that sort of thing.
Perhaps an array of 8 bytes...
Note that a double i IEEE 754 floating point is 64 bit, so two double in a struct would represent 128 bits of data.
"Note that a double i IEEE 754 floating point is 64 bit"
C51 doesn't support 64-bit floats: http://www.keil.com/support/man/docs/c51/c51_le_datatypes.htm
I know that it doesn't support the double type, which is a good reason for not using it to try to create "larger" data types.
More specifically: It doesn't support the double data type, other than as an alias for float. A double (double-precision) data type is required by IEC 60559 to be capable of supporting at least 10 decimal digits, and a 4-byte number according to the IEEE 754 standard only manages 7 decimal digits.
My answer was regarding the OP text: "I've read the data types cart, and there is no reference to 64 bit data. Is there another way to do this? (with an struct of two doubles, or something like this...)"
Obviously, two double should not be used to try to get a 64-bit data size. Especially not on a compiler that doesn't support double. The possibilities are to use two or more suitable integer data types.
"Obviously, two double should not be used to try to get a 64-bit data size. Especially not on a compiler that doesn't support double."
Ah - now I see your point. Quite so.
"The possibilities are to use two or more suitable integer data types."
Yes - although floats might give the required number of bits, there wouldn't be a lot useful that you could then do with them. Integer types would be more suitable.
Or just an array of bytes...
But then an array of bytes are normally "two or more suitable integer data types." ;)
Ok. Firts of all, thanks a lot for your comments.
I want a 64 bit unsigned integer. So the solution can be an array of 8 integers or an array of two unsigned long int (32bit), isn't it?
And for make a SIGNED 64 bit data? Perhaps a thing like this?
MSB LSB MSB LSB |------------------|---------------------| | signed int 32bit | unsigned int 32 bit | |------------------|---------------------|
MSB LSB |----------------------------------------| | signed int 64 bit | |----------------------------------------|
I think it can be like this because the sign is only allocated on the most significant bit of the data. No sign is needed on the lower long int.
"I want a 64 bit unsigned integer."
Does your code actually need to process this (ie, do arithmetic on it), or just pass it through?
If you need to do 64-bit arithmetic, you will have to implement that yourself - probably in assembler.
"the solution can be an array of 8 integers"
Note that "integer" is just a generic term for any whole number. That's why I've been careful to say "byte" where I mean specifically an 8-bit data type.
Note that you need to use the 'pre' and '/pre' tags (as for posting code) to make the diagram work:
MSB LSB MSB LSB |------------------|---------------------| | signed int 32bit | unsigned int 32 bit | |------------------|---------------------| MSB LSB |----------------------------------------| | signed int 64 bit | |----------------------------------------|
See: http://www.keil.com/forum/tips.asp
But yes - that's the kind of thing.
With the exception of add and subtract, the code to operate on larger numbers than is natively available is often simpler if you work with sign+magnitude, instead of working with two-complement numbers.
In two-complement form, you often have to negate one or both of the numbers, before they may be used in evaluations.
An example: A multiply of a number with -2 would require you to multiply the number with 0b1111...1110 in two-complement form. If you just start to multiply, you would get a huge number, before reaching the sign bit and "collapsing" the result. To avoid this, you would first have to detect the sign and negate the value -2 before starting the multiply.
If performing the multiply using sign+magnitude, you would just multiply your number with 0b10 and then set the final sign to the xor of the two original sign bits.
I think that i will use sign+magnitude. It doesn't matter a lot, because as i posted before, I don't need to make arithmetic operation. So i can use also one-complement or two-complement.
Thanks a lot for your attention.
