i have problem with passing array values from c to inline assembly pls help me &also reciving values from inlineassembly
It looks like you might have inadvertently posted before you were finished. There isn't any code or enough details describing your problem.
DROP THE INLINE, make a separate module, code it in C, use the .src directive, use that as the base for your assembler module.
That way all and everything is served to you on a silver platter.
Now you are going to tell me that you WANT to do it inline - good luck.
discussed in detail http://www.keil.com/forum/docs/thread9558.asp
