C167CS Flashloader
Here is the scenario. I am working with C167CS
The bootstrap loader is loaded between FA60 to FC00 in the internal memory.
It in turn loads a small program into the XRAM E000 to E7FF.
This is setup has worked well for us for the past 8 years unfortunately the program has now changed and cannot fit completely into the XRAM.
I have created another module and placed it at F600 to FA00 in the internal memory.
My link looks like this:
MAIN.OBJ, FLASHLDR.OBJ, SERTIMER.OBJ
TO flashldr
CLASSES (FCODE(0FA60H)) & SECTIONS(?PR?FLASHLDR%FCODE(0E000H), ?PR?SERTIMER%FCODE(0F600H))
My initialization looks like this:
#pragma asm
   ADDRSEL1 DEFR     0FE18H
   ADDRSEL2 DEFR     0FE1AH
   DISWDT                // Disable watchdog timer
   MOV   SYSCON,#6184H   // Stack size = 32 words, XRAM enabled
   NOP
   MOV   DPP0,#0         // Set the data page pointer to point at 1st 4 pages
   MOV   DPP1,#1         // which is all of internal memory
   MOV   DPP2,#2
   MOV   DPP3,#3
   NOP
   MOV  ADDRSEL1,#0803H  // CS1 active starting at 08'0000 (RAM)
   NOP
   MOV  BUSCON0,#04AFH   //  CS is independent of write
   NOP
   MOV  BUSCON1,#04AFH   // CS is independent of write
                         // EEPROM
   MOV  ADDRSEL2,#0C06H  // CS2 active starting at 0C'0000
                         // CS2 block size is 256 kbytes
   NOP
   NOP
   MOV  BUSCON2,#040AH   // CS is independent of write
                         // CS is independent of read
                         // External bus controlled by MCTC only
                         // External bus is enabled
                         // ALE is normal length
                         // 8 bit demultiplexed bus
                         // One tristate wait states
                         // Delay read/write 1 TCL after ALE
                         // 5 wait states
   EINIT
#pragma endasm
I load the new module like this:
   BYTE idata *pbIramPtr;
   BYTE bLastByte;
   // Load interal ram code -> continue loading FLASHLDR.SRE YES - ITSELF !
   // This code loads all the code in SERTIMER.C
   // The code is loaded to internal memory
   for ( pbIramPtr =  (BYTE idata *)0xF600;
         pbIramPtr != (BYTE idata *)0xFA00; pbIramPtr++ )
      // Wait for a byte to come in on the serial port
      while (! S0RIR);
      // Store the byte in internal ram
      bLastByte = S0RBUF;
      *pbIramPtr = bLastByte;
      // See if the byte was stored correctly
      if (bLastByte != *pbIramPtr)
         // Store failed, send XRAM error and lockup
         putbyte(XRAM_WRITE_ERROR);
         while(1);
      // Clear receive interrupt flag
      S0RIR = 0;
Is there any reason that this shouldn't work?
