Hi friends,
I am trying to interface EEPROM with AT89C51.For that i have written a I2C driver , in that i can able to write* the data to EEPROM but unable to read data from it.
*I have just conformed while checking SDA(Serial Data Pin) and SCL(Serial Clock Pin) of EEPROM.
>> while i am checking with CRO ,i can able to get all the clock pulse , Start , Stop , Acknowledgment's, slave address , data which i am witting to slave etc ,but except the Data which i am reading from slave ...
Project Details
/* * Hardware : Controller -> AT89C51 * XTAL -> 11.0592 MHz * Mode -> 12 Clock/MC * EEPROM -> AT24C256 with device address 0XA0 (EEPROM's A0 & A1 connected to GND) * Compiler : Keil micro version 3 * * Hardware : * 1)2.2k is connected between Vcc(+5v) to SCL & SDA lines for pull up . * 2)Write Protected Pin & NC pin is Conted to GND */
