Hello
I'm working with the AT91RM9200 from Atmel and I have some problems with data abort. The stack size is big enough. I tested it by making the user stack size zero and see which errors now occured. Everything was overwritten by other things. At the moment my stack size is 0x00000200. The error which occured is that the ptr to the usart base address is overwritten either if the usart.o is stored in the internal ram or the external ram. I use the watch window to see if the ptr would change his value - but nothing happens. I only know that the value is changed because I set a dummy within the retarget function for printf() - (thanks for the hint Per).
The whole programm only includes the ethernet init part, the usart and retarget function in separate c-files. So I have one main file with only the main routine where I init all other functions by calling the right function. In the while loop (main.c) I only poll if a flag is set by receiving a new frame by the ethernet. This works with the data abort problems.
These problems don't appear always at the same part of code. Is my acceptance right, that if I would have a stack size problem, the error would occurred always at the same part of code?
When I test the whole programm several times, I have one or two passes where no error occured. Very often the error happened bevor I call the init function for the ethernet part. So I don't think there would be a error during the execution of the code. I think the error could / must be very global. If I don't include the ethernet part, then I got no data abort error. But I'm not able to find the / or these problems.
the headerfile of the ethernet part:
#define AT91C_EMAC_TDLIST_BASE 0x21000000 /* */ #define ETH_PACKET_SIZE 1536 /* greater than 1518 or 1522 (VLAN) bytes */ #define NB_ETH_RX_PACKETS 10 /* number of RX buffer */ #define EMAC_RXBUF_ADD_WRAP 0x02 /* WRAP Bit at the end of the list descriptor */ #define MII_STS_REG 0x01 #define MII_STS2_REG 0x11 #define RxPacket (AT91C_EMAC_TDLIST_BASE + (8 * NB_ETH_RX_PACKETS)) typedef struct { unsigned int RxBufAddr; unsigned int RxBufStatus; } *EMAC_pRX_descriptor; void Phy_Init(void);
Now I delete the retarget function and the usart.c file so that I only work with the ethernet part... and now the data abort errors are not so often and if one occured then I see nothing in the new window "stack frame"...
There was only one situation were I see an red arrow to one ptr in the lib of the AT91RM9200 (newHandler form the AT91F_AIC_ConfigureIt function)... in the other situation I only see my main function (with the integer i) and the data-abort function which is called if a data abort occured... so it could be probably that there's a ptr who can have every addr at the beginning...
best regards Johannes
I just take a look at the function AT91F_AIC_EnableIt and I don't understand the value of the newHandler, which were shown in the stack window...
newHandler 0xE92D000F (I don't know this address)
__inline unsigned int AT91F_AIC_ConfigureIt ( AT91PS_AIC pAic, // \arg pointer to the AIC registers unsigned int irq_id, // \arg interrupt number to initialize unsigned int priority, // \arg priority to give to the interrupt unsigned int src_type, // \arg activation and sense of activation void (*newHandler) (void) ) // \arg address of the interrupt handler { unsigned int oldHandler; unsigned int mask ; oldHandler = pAic->AIC_SVR[irq_id]; mask = 0x1 << irq_id ; //* Disable the interrupt on the interrupt controller pAic->AIC_IDCR = mask ; //* Save the interrupt handler routine pointer and the interrupt priority pAic->AIC_SVR[irq_id] = (unsigned int) newHandler ; //* Store the Source Mode Register pAic->AIC_SMR[irq_id] = src_type | priority ; //* Clear the interrupt on the interrupt controller pAic->AIC_ICCR = mask ; return oldHandler;
When I'm right, then the newHandler should pointed to my ISR (but my ISR is at the addr 0x100003a0). I just set a breakpoint in the last line of this code, so that the newHandler should already be stored in the AIC_SVR register (which should also store the address of the corresponding handler for the interrupt source).
and that's my call in the c-file..
AT91F_AIC_ConfigureIt(AT91C_BASE_AIC, AT91C_ID_EMAC, AT91C_AIC_PRIOR_HIGHEST - 3, AT91C_AIC_SRCTYPE_EXT_HIGH_LEVEL, (void (*) (void))ethernet_interrupt);
Johannes
How can I check this by stepping through the code?
I have a stack size for the IRQ: 0x00000200 and for the user stack 0x00000600 - I think that must be enough for a small ISR
void ethernet_interrupt(void) __irq { volatile unsigned int status=0; AT91PS_EMAC pEmac = AT91C_BASE_EMAC; // clear receive status register status = pEmac->EMAC_ISR; if (status & AT91C_EMAC_RCOM) // Receive complete Emac_Receive=1; if(status & AT91C_EMAC_ROVR) overrun=1; AT91C_BASE_AIC->AIC_EOICR = 0; // End of ISR }
Now I tested 0x00000600 for the IRQ stack size and 0x00001500 for the user stack size -> and the first attempt was a data abort...
I don't have a feeling how much I need to have enough stack size, but this size seems very big to me for really nothing.. I have only the implemenation of the ethernet and a small main function where I ask if the variable Emac_Receive=1 - that's all
I make some more tests - maybe you could help me to find the problem:
I made the ISR smaller
void ethernet_interrupt(void) __irq { // volatile unsigned int status=0; AT91PS_EMAC pEmac = AT91C_BASE_EMAC; // clear receive status register status = pEmac->EMAC_ISR; if (pEmac->EMAC_ISR & AT91C_EMAC_RCOM) // Receive complete Emac_Receive=1; // if(status & AT91C_EMAC_ROVR) // overrun=1; AT91C_BASE_AIC->AIC_EOICR = 0; // End of ISR }
--> nothing has changed --> I get some data abords when ethernet frames were received.
Then I made the ISR smaller
void ethernet_interrupt(void) __irq { // volatile unsigned int status=0; // AT91PS_EMAC pEmac = AT91C_BASE_EMAC; // clear receive status register // status = pEmac->EMAC_ISR; // if (pEmac->EMAC_ISR & AT91C_EMAC_RCOM) // Receive complete // Emac_Receive=1; // if(status & AT91C_EMAC_ROVR) // overrun=1; AT91C_BASE_AIC->AIC_EOICR = 0; // End of ISR }
Now it seems that I get no data aborts, but if I received frames I can wait plenty of time but the processor always remained in the interupt mode. What's going wrong here, that the processor don't go back to the user mode?
ok I've to read the status register to go back to the user mode.
Only the data abort remained if I receive frames.
I see there two problems: - one could be the call of the ISR -> one ptr who has no correct address (because the data abort happens not always only sometimes when I get new ethernet frames.
- the other problem could be the dma process to store the data --> but the dma have to store the data into the sdram first, and then the interrupt occurred that new data are there... I also check if the data stored in the sdram at the correct place (and that's working)...
- the stack size is really big enough, so that there could be no problem.
- there's nothing in my programm beside the ethernet init
- if there are no new ethernet frames - no data abort
I also think that the error occured when I leave the ISR, because when I forget to read the status register (the ISR is also called and the data is also stored in the sdram) I have no data abort error.
Don't play around at random.
You have yourself said that:
and
If your newHandler pointer is invalid when you initialize the interrupt, then the processor will jump to an invalid location when the interrupt gets trigged.
In that case, it is quite meaningless to look at the ISR stack size. Have you made sure that the correct ISR vector is configured? And that the correct ISR vector is still set when you get to the exception handler?
If - as you say - the newHandler pointer is invalid in the function that configures the interrupt, then there is a total waste of time to continue with the program - you have to find out where newHandler becomes corrupt - is that in the function call, or caused by incorrect code generation at high optimization levels or is it just the debugger that shows wrong values because it thinks that newHandler has gone out of scope, allowing the compiler to reuse a register for something else?
Remember that you may also get other interrupts while initializing the ethernet ISR.
Always try to split your problems into pieces and figure out if the problem occurs before or after your split point. If you don't break your problems into smaller problems then you will never find a solution.
In my programm I only configurate this interrupt. the Emac controller have more interrupts which uses the same ISR, but they don't occured. But I could disable all interrupts beside the "Received Complete".
The whole programm is very small.
I don't understand the value of the newHandler, which I see in the stack window. Because the address is invalid and not the correct address of the ISR - thats true. but I don't know how this function will work with this pointer.
If that would happened then it must happened on every try - but I think 70% of my attempts to run the programm ends with a data abort - so the problem is no problem which always will occur - so a pointer with no correct start address is one example of such a thing.
If I set a breakpoint bevor the ISR, the ISR will never be called, because all interrupts will be turned off. So I've only the chance to set a breakpoint during the ISR or when a data abort occured...
I asked these two questions - haven't seen any answer: Have you made sure that the correct ISR vector is configured? And that the correct ISR vector is still set when you get to the exception handler?
yes I use the correct vector from the AIC for the ethernet - I checked the value in the header-file from Keil for this controller.
AT91F_AIC_EnableIt( AT91C_BASE_AIC, AT91C_ID_EMAC);
where AT91C_ID_EMAC is
#define AT91C_ID_EMAC ((unsigned int) 24) // Ethernet MAC
and that's correct.
I wasn't thinking about the number.
I was thinking about the address it points to. Does it point to your ISR?
If i wrote
if(AT91C_ID_EMAC != (unsigned int) 24) Emac_Receive=0;
then it is never correct - but I'm not sure if this is the correct request.
Moreover I tested this:
if(AT91C_AIC_SVR[AT91C_ID_EMAC] != 0x1000032c) Emac_Receive=0;
AT91C_AIC_SVR: in this register should be stored the addresses of the corresponding handler for each interrupt source. My address of the function ethernet_interupt is 0x1000032c, which I can read out of the .map file.
But it fails... the correct address of the ISR is not stored.
within the function AT91F_AIC_ConfigureIt:
which should be the ISR in the call of this function:
and stored in this register...
Now I think I've found the problem, but I don't know why this could be the problem...
I've one c-file where I install the ethernet PHY. At the beginning of this c-file is the ISR for the PHYs.
I installed one global variable Emac_Receive (at the top of this c-file)
volatile unsigned int Emac_Receive=0;
Within the ISR I changed the value of this variable if a ethernet frame is received (Emac_Receive=1). So it should be my flag (I don't know if there's a better routine to do that).
I have another c-file with the main.c where I called the first function for the initialisation of the ethernet PHYs. In the while(1) loop I always polling the variable Emac_Receive if there's a new ethernet frame received...
if (Emac_Receive==1)
At the top of this c-file I wrote:
extern unsigned int Emac_Receive;
If I comment out the polling routine within the main routine, then I get no data abort error...
But why could there be a error? What I'm doing wrong here?
I get also a data abort error, if I write the ISR at the top of the main.c-file.
Is there a problem with the extern reference?
Bad idea. Make it a rule: Never write "extern" in any .c file. Declarations interfacing one module to the next belong into the interface description of the exporting module, i.e. the corresponding .h file (and don't forget to #include that header in the defining module, too!).
As an extra advantage, this would have immediately caught the discrepancy between definition and declaration: you missed the "volatile".
I wrote in the extern declaration into the headerfile, but the data abort error occured again. I included this headerfile to both of the two c-files.
extern volatile unsigned int Emac_Receive;
You seem to like to experiment.
Have you played around with the linker, causing it to place this variable at a bad place?
I wrote my own linker script (scatter-file) - but if I use the linker script file from Keil it caused the same error (blinky-example).
When I took a look into the watch window, I'm able to see the address of the global variable Emac_Receive and this address seems to be ok.
Options for target > linker: I only insert my scatterfile and the activiation for (report might fail conditions as Errors) - I made no other settings.
