We are trying to disable two fast interruptions as we get another one.
We are using XC167CI.
We have managed to do it but when we enable them again, the associated function executes once if there is a request pending.
We have seen in the manual that it may be because the IR bit in the Interrupt Control Register so we have tried to put 0 in this bit but it is not possible as it supports bit-protection.
Is ther any possibility to change this bit? Any other way to avoid this problem without using auxiliary variable?
Thanks,
Willow
