I have a problem when I try to get a function to update a the address of a pointer. Code:
const unsigned char array1[10] = {1, 2, 3, 4....} void func1 (const unsigned char *ptr) { ptr = array1; } void func2 (void) { const unsigned char *ptr1; func1 (ptr1); if (ptr1[0] == 1) { ..... } }
The problem is, the ptr in func1 gets the right address, but when I return to func2, ptr1 doesn't get updated. I have tried to remove the const from the variable definition in func2 without any succes.
array1 must be defined as a const because in the real code it's a lot bigger.
I have tried to set ptr1 directly in func2.
... void func 2 (void) { const unsigned char *ptr1; ptr1 = array1; if (ptr1[0] == 1) { ..... } }
This work fine. But this is not an option in my application.
uC: STR712 compiler: CARM
Try this:
void func1 (const unsigned char **ptr) { *ptr = array1; } void func2 (void) { const unsigned char *ptr1; func1 (&ptr1); if (ptr1[0] == 1) { ..... } }
Actually this is textbook C stuff. You might want to consult your favorite C book once more.
- mike
That solved the problem..... Thanks
I did mean change the address the pointer is pointing to not "update the address of a pointer." ;-)
Thats the problem when my text book i missing.... :-(
