time_t is defined in time.h as :
typedef unsigned int time_t;
In my opinion it should be defined as :
typedef long time_t;
Am I right ?
No.
The standard says that time_t is an arithmetic type. It also says that integer and floating types are collectively called arithmetic types. So time_t could just as legitimately be a floating type.
Yes, that is the traditional definition, even for 64-bit architectures. However, you shouldn't rely on it, since it isn't required. The whole point of having a named data type time_t is to allow implementations to change the actual data type used.
If you want to print it, you should probably think about
printf("Time: %lu\n",(long)t);
Better make that:
printf("Time: %lu\n",(unsigned long)t);
Or, if available, make use of the extensions to integer types and printf formats in Standard C99.
Slip of the finger. The typecast is correct, but it should be "%ld", and not "%lu". The time_t datatype is signed just because it should be possible to store a negative difference in it.
This is the big reason why the data type isn't just changed from long to unsigned long - a lot of programs would break then. In early 2038, we will see if your microcontrollers have suddenly become 64-bit or if a lot of hardware appliances will suddenly break :)
C99 isn't always available :(
Thank you for all replies ! As I understand function time_t time(time_t *) should return the number of seconds elapsed since january/1970. If this is true an int wouldn't be enough.
Depends on processor. You need a 32-bit data type, and you are talking about ARM, so you are in the clear.
It isn't number of seconds since january 1970 but number of seconds since 00:00 January 1st 1970, or since 1969.
