MON51 hack
First let me describe a little bit about our system:
It is not von-neuman, and the main code executes from OTP (One Time Programable) memory. there is also a small amount of XRAM, and code can also be executed from there too.
When executing from OTP, we are unable to use MOVX to read or write CODE. We can use MOVC read CODE.
When executing from XRAM, we are unable to use MOVX to read or write XDATA. We can use both MOVC and MOVX to read CODE.
Despite being OTP, we do have the ability to dynamically patch an small number of quads of OTP code at any address to whatever value we choose.
My belief is that all the elements that are needed to execute a MON51 stub from OTP are present. We can patch code to jump to the stub on a break point, and code can be read through the MOVC to keep adjacent instructions coherent in the patch?
My question is, does anyone have any experience or deep working knowledege of the MON51 that can point me to section that inserts the jumps that set and clear break points? Are there any thoughts about how to modify this with minimum impact on the stub?
Thanks in advance,
Chris.
