Hi everyone,
Can I connect MCBSTM32 demo board via Segger's J-Link and debug programs with MDK-ARM?
Thanks.
Yes, but you "MAY" need to obtain an RDI Interface driver from Segger. You can get a trial version from them valid for 30 days. You can buy the software for 198 Euros. You can buy a Keil Ulink2 for about 200 Dollars and then you do not need a RDI Interface driver.
Thank you for reply.
I have RDI driver from Segger. Can you tell me how to configure it?
All Segger software is FREE for NXP processors!
Georg
As you say, it's from Segger - so Segger are the ones to contact for support!
You mean this: www.segger.com/jlink.html ?
I had a quick look, but didn't see this mentioned at http://www.segger.com
Can you give a link to confirm it?
Segger JLINK is similar to SAM-ICE.
The usage of SAM-ICE is explained in: http://www.keil.com/appnotes/docs/apnt_190.asp
You should be able to use the same with the SEGGER product.
www.segger.com/news_070412_NXPfreeflashbreakpoints.html
I configure RDI driver as explained in http://www.keil.com/appnotes/docs/apnt_190.asp. When I select Flash\Download in uVision3 I see mesages: uVision-Flasher-ARM Error: STM32F10x_128.FLX Cannot Load Flash Programming Algorithm and uVision3 Error: Flash Download failed-"Cortex-M3" What does it means?
