Hi everyone,
Can I connect MCBSTM32 demo board via Segger's J-Link and debug programs with MDK-ARM?
Thanks.
You mean this: www.segger.com/jlink.html ?
Segger JLINK is similar to SAM-ICE.
The usage of SAM-ICE is explained in: http://www.keil.com/appnotes/docs/apnt_190.asp
You should be able to use the same with the SEGGER product.
I configure RDI driver as explained in http://www.keil.com/appnotes/docs/apnt_190.asp. When I select Flash\Download in uVision3 I see mesages: uVision-Flasher-ARM Error: STM32F10x_128.FLX Cannot Load Flash Programming Algorithm and uVision3 Error: Flash Download failed-"Cortex-M3" What does it means?
