install dara abort ISR
Hello again,
I'm working with the AT91RM9200 controller. How is it possible to get a printf() message over the usart1 if a dara abort or undefined instruction has occured?
I've one .c file with all ISR; for example:
void AT91F_DataAbort()
        printf("Data Abort detected\n");
        while (1);
and the void AT91F_LowLevelInit() function.
But which changes I have to made in the startup code file to run this function is a data abort occured?
IS it something like that (I've found in the www)
IMPORT AT91F_LowLevelInit
                                ldr r1, = AT91_SVC_Stack_Begin
                                bic r1, r1, #3 ; Insure word alignement
                                mov sp, r1 ; Init stack SYS
                                ldr r0, = AT91F_LowLevelInit
                                mov lr, pc
                                bx r0
; Setup Stack for each mode
                LDR     R0, =Stack_Top
Maybe someone of you could give me a example, where I could see the changes in the startup code.
best regards
Johannes
