Port configuration
my question is about the power on / reset values of the 8051 ports:
at power on /reset, the port latches are loaded with FFh hence there are configured as inputs or outputs.
The 8051 Microcontroller and Embedded System
Using assembly and c by MUHAMMAD ALI MAZIDI JANICE GILLISPIE MAZDI ROLIN D. McKINLAY second edition PEARSON EDUCATION mentions that they are configured as inputs.
But most websites mention that,at power on /reset the port are configured as outputs .
which is correct?
also look at the following code that monitors a switch connected to P1.5 and sets P1.7 if P1.5 is high
SETB P1.5 ; set P1.5 as input L1:JNB P1.5 ,L1 ; continuously poll P1.5,exit the loop if P1.5 SETB P1.7 ; set P1.7
will not the first instruction, SETB P1.5 itself produce an erroneous output since the port 1.5 pin has already been set high by the instn. SETB P1.5.
Thank you
