last week I got my uvision 3 with ulink2.
Now I get this error message "this version of the linker will not create images that large L6047U". I installed the LIC key and when I open the licence management I can read DK-ARM Developers Kit under the Product point.
I'm working with the RealView Compiler - maybe that would be the problem and I can only use the GNU Compiler with this version of uvision?
best regards Karl
Karl; Keil Tech Support does not usually monitor this forum. If you suspect LIC problems, you should go directly to Keil Tech Support. I have found they are very responsive to this type of problem. Bradford
www.lpctools.com/index.asp
I only want to know if the DB-ARM version includes the realview compiler or not - or only a small version which works until 16kBit or something else... (the description is not so clear)
Maybe anybody of you use the small DB-ARM version from keil
no there's no realview compiler - or only a small version
www.logic-technology.com/s_keil.asp
best regards Johannes
