Dear all, I want to start project with rgb led, what MCU i can use, ARM, AVR or PIC ? I have need 3 PWM Hardware not less than 10 Bit resolution, and eeprom memory inside mcu.
I must do 100% work myself.
Thank you for any comment or example similar project.
xgnetto
If you want to use Keil tools, the last two families are out of the picture. But maybe you can use a '51 derivate ?
And what project is this supposed to be ? What's the "rgb led" supposed to do ?
I want to start project with rgb led, what MCU i can use, ARM, AVR or PIC ? if it is one LED - any of them. if it is a lot of LEDs - any that is fast enough.
"project with rgb led" - wery descriptive i see all the datails clearly.
also, as you have listed MCU as ARM, it seems you have already mad the choice.
<bold>it seems you have already mad the choice.</bold>
yes; i think you are right. Does The arm Have 3 PWM Hardware With Not Less Than 10 Bit Resolustion?
i Do search for rgb leb but I cannot find it.where can i Get one ?
