Can LOAD file to a specified memory area ?
The command "SAVE" can be used to save a specified memory to hex file. So, my question is that there is any command for loading a file into a specified memory area?
For example, I have a hex file, I want to write it into external memory from 0x0100 to 0x0200. The website http://www.keil.com/support/man/docs/uv3/uv3_cm_load.htm is about command "LOAD", but it seem can not load file into a specified memory.
Thank you for helping.
Best Regard.
