C51: Questions regarding SYSCLK
i am a student and needs some help.
Can someone help solve some of my doubts?
Hmm..may i know what does it means by SYSCLK/12/10?
How can i go about calculating the timer values using the SYSCLK/12/10 if i want to use the codes below to make the LED blink at 1Hz?
Thanx=)
// MAIN Routine
void main (void) {
   // disable watchdog timer
   WDTCN = 0xde;
   WDTCN = 0xad;
   SFRPAGE = CONFIG_PAGE;                 // Switch to configuration page
   PORT_Init ();
   SFRPAGE = TMR3_PAGE;                   // Switch to Timer 3 page
   Timer3_Init (SYSCLK /120/10);        // Init Timer3 to generate interrupts
                                          // at a 10 Hz rate.
   EA = 1;        // enable global interrupts
   SFRPAGE = LEGACY_PAGE;                 // Page to sit in for now
   while (1) {                            // spin forever
// PORT_Init
// Configure the Crossbar and GPIO ports
void PORT_Init (void)
   XBR2    = 0x40;                     // Enable crossbar and weak pull-ups
   P1MDOUT |= 0x40;                    // enable P1.6 (LED) as push-pull output
// Timer3_Init
// Configure Timer3 to auto-reload and generate an interrupt at interval
// specified by <counts> using SYSCLK/12 as its time base.
void Timer3_Init (int counts)
   TMR3CN = 0x00;                      // Stop Timer3; Clear TF3;
                                       // use SYSCLK/12 as timebase
   RCAP3   = -counts;                  // Init reload values
   TMR3    = 0xffff;                   // set to reload immediately
   EIE2   |= 0x01;                     // enable Timer3 interrupts
   TR3 = 1;                            // start Timer3
// Interrupt Service Routines
// Timer3_ISR
// This routine changes the state of the LED whenever Timer3 overflows.
// NOTE: The SFRPAGE register will automatically be switched to the Timer 3 Page
// When an interrupt occurs.  SFRPAGE will return to its previous setting on exit
// from this routine.
void Timer3_ISR (void) interrupt 14
   TF3 = 0;                               // clear TF3
   LED = ~LED;                            // change state of LED
