problem comparing signed char
hi i am trying to compare the value of two signed chars. one is a plain variable currentval while the other is a signed char inside an array of type signed char called spectrumarray.for some reason it doesnt work.
xdata signed char spectrumarray[256];
signed char currentval;//current value at this freq
int xdata channel;
for(channel=0;channel<256;channel++){
  for(sample=0;sample<70;sample++){//sample 70 times at this freq
  currentval=halSpiReadStatus(CCxxx0_RSSI); //this just reads a register from some a source external to the microcontroller
    if((signed char)spectrumarray[channel] < (signed char)currentval)
      spectrumarray[channel]=currentval; //want to put currentval  into the array if it is more than the value currently in the array
printf("%Bd\n\r",(signed char)currentval);
//did this just to check to see what the currentval was
Used this to initalize the array
void init_array(void){
  int xdata arrayindex;
  for(arrayindex=0;arrayindex<256;arrayindex++){
        spectrumarray[arrayindex]=-128;//initialize to the lowest value possible
I am sure the currentval values are more than what is inside the array when they are compared, yet when i print out the whole array it only holds -128 for every value except the last.I'm kind of stumped.oh yea forgot to mention im also new to the C51. microcontroller in use is the Silabs C8051F320.
  • "microcontroller in use is the Silabs C8051F320."
    That has on-chip debug, doesn't it?
    Rather than mess about with printf (which could introduce bugs of its own), have you single-stepped through the code and examined what's actually happening in the chip at eah step?
    Have you tried your code in the simulator?
