on-chip xdata on aduc832
Can anyone please help explaining me why this code won't access the on-chip xdata. When executing the below code nothing happens at all.
#include <ADUC832.H>
#include  <stdio.h>
void main (void)
  xdata int m[10];
  int j;
Configure the serial port to run at 9600 Baud.
        PLLCON = 0xF0; // core clock 16.78 MHz
        PCON |= 0x80;    // Set SMOD i.e. double baudrates
        SCON = 0x50;   // SCON: mode 1, 8-bit UART, enable rcvr
        TMOD = 0x20;   // TMOD: timer 1, mode 2, 8-bit reload
        TH1 = -9;            // TH1:  reload value for 9600 baud
        TR1 = 1;       // TR1:  timer 1 run
        TI = 1;
  for(j=0;j<10;j++)
    m[j] = j;
  for(j=0;j<10;j++)
        printf("int m[%i] = %i\n", j, m[j]);
        while(1);
In the startup code (START_AD.A51) I did enable xdata access
; XRAMEN     Val  Description
XRAMEN EQU 1; 0 = disable on-chip XDATA RAM and access off-chip XDATA space
;           ; 1 = enable on-chip XDATA RAM
If I change to XRAMEN EQU 0 and run the code, the output is ten "-1" on the serial port (this I understand as xdata isn't available)
