Setting interrupt flag when a specific key has be enter
Hi!
For a few months i started programming with ARM7(CPU:LPC 2138).I have this interrupt driven UART I/O:
 void sio_irq (void) __irq {
  volatile char dummy;
  volatile char IIR;
  struct buf_st *p;
  Repeat while there is at least one interrupt source.
  while (((IIR = U1IIR) & 0x01) == 0) {
     switch (IIR & 0x0E) {
       case 0x06: /* Receive Line Status */
         dummy = U1LSR;  /* Just clear the interrupt source */
         break;
       case 0x04: /* Receive Data Available */
       case 0x0C: /* Character Time-Out */
         p = &rbuf;
         if (((p->in - p->out) & ~(RBUF_SIZE-1)) == 0) {
           p->buf [p->in & (RBUF_SIZE-1)] = U1RBR;
           p->in++;
         break;
       case 0x02: /* THRE Interrupt */
         p = &tbuf;
         if (p->in != p->out) {
           U1THR = p->buf [p->out & (TBUF_SIZE-1)];
           p->out++;
           tx_restart = 0;
         else {
           tx_restart = 1;
         break;
       case 0x00: /* Modem Interrupt */
         dummy = U1MSR;  /* Just clear the interrupt source */
         break;
       default:
         break;
  VICVectAddr = 0; /* Acknowledge Interrupt */
int __swi(8) com_putchar (int c);
int __SWI_8              (int c) {
  struct buf_st *p = &tbuf;
/*------------------------------------------------ If the buffer is full, return an error value. ------------------------------------------------*/ if (SIO_TBUFLEN >= TBUF_SIZE) return (-1);
/*------------------------------------------------ Add the data to the transmit buffer. If the transmit interrupt is disabled, then enable it. ------------------------------------------------*/ if (tx_restart) { tx_restart = 0; U1THR = c; } else { p->buf [p->in & (TBUF_SIZE - 1)] = c; p->in++; }
return (0); }
int __swi(9) com_getchar (void);
int __SWI_9              (int c) {
  struct buf_st *p = &rbuf;
  if (SIO_RBUFLEN == 0)
    return (-1);
  return (p->buf [(p->out++) & (RBUF_SIZE - 1)]);
How can i modify this so that only when a specific character(for example:'#') is given then the interrupt flag is setting?
Thank you in advance for any help.
