error C129 : missing ";" before xdata
I'm converting some C code from Archimedies to Keil version 7.0 and I don't know why this error C129 is popping up. I thought is was because in Archimedies xdata came before uchar so I switched around all xdata variables in the Global.c and Global.h files but still had the error. So I inserted a new #define line above the error point but still have the error. Here is how the codes is written and the error message points to the BOLD text line:
Global.c file
#include "header.h"
#include "global.h"
/* The following are BIT status errors */
uchar xdata arincReceive0Counter;
uchar xdata arincReceive1Counter;
uchar xdata CurrentlyUsedARINC;
Global.h file
#define ARINC_CHAN0_CHK_BSY ARINC_CHAN0 + ARINC_CHK_BSY
#define ARINC_CHAN0_USED ARINC_CHAN0 + ARINC_USED
#define ARINC_CHAN1_CHK_BSY ARINC_CHAN1 + ARINC_CHK_BSY
#define ARINC_CHAN1_USED ARINC_CHAN1 + ARINC_USED
extern uchar xdata arincReceive0Counter;
extern uchar xdata arincReceive1Counter;
extern uchar xdata CurrentlyUsedARINC;
Got any ideals?
