I wan't toggle a pluse on P2.7 I've wrote a debug ini file to load in keil uVDebuger. It compiled with no error.
but when i invoke one of the user function in command window error occured : *** function 'IrKey', error 99, line 41: signal() already activated
my ini file list below,can anyone help?
SIGNAL void IrStart(void) { P2&=0x7f; swatch(0.009); P2|=0x80; swatch(0.0045); } SIGNAL void IrDat0(void) { P2&=0x7f; swatch(0.00056); P2|=0x80; swatch(0.000565); } SIGNAL void IrDat1(void) { P2&=0x7f; swatch(0.00056); P2|=0x80; swatch(0.001685); } signal void IrStop(void) { P2&=0x7f; swatch(0.00056); P2|=0x80; swatch(0.000565); } FUNC void IrKey(unsigned char key) { unsigned char i; IrStart(); for(i=0;i<8;i++) {if(key&0x7f) IrDat1(); else IrDat0(); key=key<<1; } IrStop(); }
It looks like IrDat0 or IrDat1 is still executing the second time you invoke them. I'm not exactly sure what line is line 41.
You may need to use a delay between shifting out the bits in the IrKey function--which means IrKey must also be a signal.
Also in IrKey, key&0x7F tells you if any bit but the MSB is set. Is this what you REALLY want?
Jon
