Problems interfacing (M41T0)SERIAL REAL-TIME CLOCK
hi
I want to interface a SERIAL REAL-TIME CLOCK (M41T0). The problem comes reading from the build-in registers, that's what I think. The code looks like this. The master device in this case is P89C51RC2BA chip. I think I have to work on BCD values as well
thanks.
// Routine: i2c_start
void i2c_start(void)
{ SDA = HIGH; // Set data line high SCL = HIGH; // Set clock line high SDA = LOW; // Set data line low (START SIGNAL) SCL = LOW; // Set clock line low
} // Routine: i2c_stop
void i2c_stop (void)
{ unsigned char input_var;
SCL = LOW; // Set clock line low SDA = LOW; // Set data line low SCL = HIGH; // Set clock line high SDA = HIGH; // Set data line high (STOP SIGNAL) input_var = SDA; // Put port pin into HiZ
// Routine: i2c_write
void i2c_write (unsigned char output_data)
{ unsigned char index;
for(index = 0; index < 8; index++) // Send 8 bits to the I2C Bus { // Output the data bit to the I2C Bus SDA = ((output_data & 0x80) ? 1 : 0); output_data <<= 1; // Shift the byte by one bit SCL = HIGH; // Clock the data into the I2C Bus SCL = LOW; }
index = SDA; // Put data pin into read mode SCL = HIGH; // Clock the ACK from the I2C Bus SCL = LOW;
// Routine: i2c_read
unsigned char i2c_read (void)
{ unsigned char index, input_data;
input_data = 0x00; for(index = 0; index < 8; index++) // Send 8 bits to the I2C Bus { input_data <<= 1; // Shift the byte by one bit SCL = HIGH; // Clock the data into the I2C Bus input_data |= SDA; // Input the data from the I2C Bus SCL = LOW; }
return input_data;
void main()
{ //After Initializing CPU, set default values to the //registers
i2c_start();
i2c_write (0xD0); //start condition followed by the //correct slave address(D0h). //////////////////////////////////////////
//The 8 bytes contained in the device can then be
///accessed sequentially in the following order:
//1. Seconds Register
//2. Minutes Register
//3. Century/Hours Register
//4. Day Register
//5. Date Register
//6. Month Register
//7. Years Register
//8. Control Register
i2c_write(0x00); // Write 00 to seconds word
i2c_write(0x59); // Write 59 to minutes word
i2c_write(0x23); // Write 23 to century/hours word
i2c_write(0x05); // Write 05 to day word
i2c_write(0x10); // Write 10 to date word
i2c_write(0x11); // Write 11 to month word
i2c_write(0x05); // Write 05 to year word
i2c_write(0x00); // Write 00 to control word
i2c_stop(); // Issue stop signal
i2c_start(); // Issue start signal
i2c_write(0xD0); // Address M41T0 To Write
i2c_write(0x00); // Start address 0 (Seconds)
i2c_write(0xD1); // Address M41T0 To Read
cksec = i2c_read(); // Read Seconds from RTC
ckmin = i2c_read(); // Read Minutes from RTC
ckhrs = i2c_read(); // Read Hours from RTC
ckday = i2c_read(); // Read Days from RTC
ckdat = i2c_read(); // Read Seconds from RTC
ckmth = i2c_read(); // Read Minutes from RTC
ckyer = i2c_read(); // Read Hours from RTC
ckctl = i2c_read(); // Read Days from RTC
arr[0] = (char)cksec;//type cast BCD value to char
arr[1] = (char)ckmin;
arr[2] = (char)ckhrs;
arr[3] = '\0';
Printf(0xB4,0x10,arr); //prints value on LCD
