Hi there, This is with respect to Keil USB mass storage example program (LPC2368 based MCB 2300 evaluation board is being used). The program works fine when compiled with Real View Compiler and tested. But, with the GNU compiler it doesnot work. No errors are being reported.
I have done the following changes and would like to know if this is correct and if any additional things need to be taken care of.
In Keil's Real view compiler based example code for which the packed attribute used is
*((__packed DWORD *) pData) = RX_DATA;
and in GNU compiler, code i have modified for packed attribute as follows
*((__attribute__ ((packed)) DWORD *) pData) = RX_DATA;
This was discussed recently - try a 'Search' of the forum...
