Where can I find the corrected ETM pinout for the MCB2300 Ver 3.1 schematic?
www.keil.com/.../mcb2300_to_schematics.htm
The schematic you posted is ver 3.0, like the one available under the MCB2300 web page is also version 3.0. The version 3.0 schematic is said to be wrong under "problem with ETM connector" references. It says the connector pinout was corrected is version 3.1. Is there a version 3.1 schematic available? Thanks
You don't need new schematics since there was no error in the schematics of the ETM pin connector. The PCB layout of the ETM was wrong (mirrored) which is now fixed.
http://www.keil.com/support/docs/3359.htm
