hi all , I need some document regarding the MII & RMII , some body please tell me where i can get the details regarding this,
Thanks, Paul
Check the data sheets for ARM devices with embedded ethernet (LPC2378) and PHY devices.
MII (Media Independent Interface) is a 4-bit interface running with 25MHz clock.
RMII (Reduced Media Independent Interface) is a 2-bit interface with 50MHz clock.
www.national.com/.../rmii_1_2.pdf
Franc
