Is there any refactoring tools/plug-ins/add-ons (even 3rd party) available for Keil IDE?
or
Has anyone done this sort of things any other way (any standalone tools/applications)?
Many Thanks for your suggestions and help
To do what?
http://www.keil.com/appnotes/list/uvision.htm
www.c51.de/.../uVision2DLLs.php
Probably refactor source code, i.e. nothing to do with simulation/emulation of hardware or peripherials.
Yes, exactly I want to refactor the source code [preferably from within the IDE] by use of some tools.
As an example : some other IDEs (eg: Visual Studio 2003) support 3rd party plug-ins (eg: Visual AssistX) that you install and allow you to perform standard refactoring jobs such as enabling you to rename a variable and all of its references at the same time inside all your project files with a simple right-click on one of the references or instances. [Currently the available way to do the above operation in Keil IDE is: 1-do a "Find in files..." to see all of the codes containing the specified name
2-Check one-by-one whether the name is of the same scope and type that you want to refactor
As you see this way is more error-prone and more time consuming than with a refactoring tool]
I am very interested to know if Keil IDE supports such plug-ins and if so, how can I obtain them [I really need such tools now].
Many thanks for your information
I'm still not entirely sure what you're trying to do, but it sounds to me like this is purely a source-code exercise? If that is the case, then you don't really need the Keil tools at all, do you?
You could do this "refactoring" exercise in Visual Studio (or whatever) - you don't need the Keil tools until it comes to actually building the "refactored" project for the target, and simulating and/or debugging it...
You could take it a step further, and use VS as your IDE for the Keil compiler, linker, etc - instead of uVision...
Yes you are absolutely right, the total job is a source-code matter only. But as you know it would be great if after any refactoring I could instantly rebuild the project to ensure the changes were safely performed.(A refactoring tools embedded in Keil IDE would be ideal, however external refactoring tools will be still useful)
Wow, thanks for the suggestion, I didn't even think that is possible. It would be great if I could do the job this way [is there any instructions available on this?]
Many Thanks
"is there any instructions available on this?"
That would be in the Visual Studio documentaion, surely?
I am currently working on a project that uses MSVS with the GNU tools, so it is certainly possible...
Thanks, you helped me a lot.
Now this seems that calling my C51 compiler, linker and assembler from MSVS should be the solution to my problem. This way I will be able to use my Refactoring tools as before from within the MSVS IDE. [I hope my refactoring tools will support ANSI-C]
Thanks again.
Unless your refactoring tools relies on the browser database created when using the original M$ compiler to build the project.
It's not difficult to make your embedded code compilable with the MS (or any other) compiler - in fact, it's often beneficial to do so!
Of course, you're unlikely to get it to run meaningfully on a PC - but that's not the point.
See: www.8052.com/.../read.phtml
