Having some problems working with a struct typedef. In RTX51, one of the system functions takes as an argument a pointer to a struct:
//function prototype signed char os_check_mailboxes (t_rtx_allmbxtab xdata *table); ... /* Type definition for system call os_check_mailboxes */ typedef struct { unsigned char message_cnt; unsigned char read_task_cnt; unsigned char write_task_cnt; } t_rtx_allmbxtab[8];
I've never seen an array-of-structs declared within the typedef before, and couldn't find any literature about it. It's declared like a single struct, and used just like an array of structs:
t_rtx_allmbxtab xdata mytable; if(mytable[x].message.cnt < 2)...
however, I get a warning "C182: pointer to different objects" when trying to use it with the actual system function (exactly as shown in the RTX51 user manual):
os_check_mailboxes(&mytable); //<-- generates warning!
I'm not sure exactly how the array as part of the data type affects this, so i'm stumped. However, that didn't stop me from trying random things to see what DID work. Here's what I came up with; maybe somebody can explain to me why this works:
//declare as an array, effectively making a 2D array //with one dimension being size 1 only t_rtx_allmbxtab xdata mytable[1]; //use as a normal 2D array if(mytable[0][x].message.cnt < 2)... //system function now works fine. no warnings. os_check_mailboxes(&mytable); //using (&mytable[0]) or (&mytable[0][0]) instead will generate 'pointer to different objects' warnings.
