this is manoj im using 89c52 microcontroller .im unable to transmit the data serilally for 115200 baud rate . but im able to transmit thro 9600 baud rate configuration.
i tried using X2 mode by configuring baud rate control register baud reload register pcon register clock control register
can anyone give the example for configuring the registers in x2 mode for baud rate of 115200
http://www.keil.com/support/docs/1905.htm
sir i want the data to transmit the in x2 mode for 115200 it is not possible in x1 mode i wantan example to configure the registers in x2 mode for 115200 baud rate.
The Baud Rate Calculator gives you everything you need:
http://www.keil.com/c51/baudrate.asp
