I am running application on u-vision2's simulator. I want to check out module wise time-complexity.
Clock freq. for my device is 60 MHz [lpc 2138], I have adjested PLL Multiplier =2 , and PLL div=2
Now, Should I aspect that what timing values i am getting for the code is derived from 60 MHz freq.
If not, what should i do to get execution time values for some XYZ code block? Can you pls. advice ?
Please see:
www.keil.com/.../uv3_db_dbg_perfanalyzer.htm www.keil.com/.../uv3_db_dbg_execprofiler.htm http://www.keil.com/support/man/docs/uv3/uv3_ui_statusbar.htm
